douds
Inscrit le: 09 Juin 2006 Messages: 1201 Localisation: Marne la vallée
Posté le: 27 Sep 2006 17:57 Sujet du message: Connaissez vous la T-REX |
Un jouet pour les Ricains:
specs T-REX:
Chassis: Multi-tubular steel chassis frame.
Engine: 1164cc Inline 4 cyl., DOHC, with Ram-Air.
Transmission: Sequential 6-Speed close ratio gear box, purpose designed reverse gear, rear wheel torque damper.
Front suspension: Unequal opposed triangular arms, adjustable dampers with coil overs, sway bar.
Rear suspension: Swinging arm, dual adjustable dampers with coil overs.
Steering: Rack and pinion (2.75 turns lock-to-lock), leather steering wheel.
Brakes: Front discs: Cross-drilled discs, 11in.(280mm) diameter, 4-piston aluminum calipers.
Rear discs: Cross-drilled disc, 10in.(254mm) diameter, 2-piston aluminum caliper.
Wheels and Tires : Aluminum 16"x7" front, 17"x10" rear, 205/45/ZR16 front tires, 285/40/ZR17 rear tire.
Body: Reinforced fiberglass plastic-sandwich construction, carbon fiber windscreens and headrests.
Cockpit: Side-by-side 2-person seating, adjustable backs, adjustable foot-pedal box, 3-point retractable safety belts.
Dimensions: Wheelbase: 90in(2286mm);
Width: 78in.(1981mm);
Length: 138in.(3500mm);
Height: 42in.(1067mm);
Dry Weight: 900lbs (410kg).
Fuel Capacity: 7.5 US gal. (28L).
Performance: 0-60 mph: 4.1 sec.
Top speed: 140 mph.
Lateral acceleration: over 1 g
Rassemblement de dino
Video:
http://www.go-t-rex.com/video/1.wmv
http://www.go-t-rex.com/video/3.wmv
http://www.go-t-rex.com/video/T-Rex_video.wmv
enfin une idée de cadeau pour noel (44000 $)
-=TroféO=-
Posté le: 27 Sep 2006 20:12 Sujet du message: |
A enfin je vois à quoi ça ressemble!!!!!!!!!!!!!
Dans une interview, Tony Parker expliqué qu'il s'était acheté un T-rex et que son club l'avait interdit de conduire ce genre d'engin, trop dangereux. ^^
J'en veux un!!!!!  _________________ Yaris 2 D-4D 90 Multimédia (version Sol + GPS intégré) de 2007 |
Posté le: 28 Sep 2006 11:29 Sujet du message: |
| c'est livré avec les pouffiasses blondes ? |
Posté le: 28 Sep 2006 15:41 Sujet du message: |
ça doit tout de même être sacrément impressionnant à conduire cet engin. Ca à l'air de pousser très fort. En plus ont doit avoir une sacré impression de vitessevu comme c au raz du sol.
Très bon topic  _________________ - Dans des temps anciens une magnifique peugeot 205 GLD !
- EX Alfa 147 JTD 115
- Ex Alfa GT JTD 150
- Ex Alfa MiTo 1.4 Tjet 155
Cuore Sportivo 67
Inscrit le: 14 Aoû 2005 Messages: 1459 Localisation: Alsace du Nord (67)
Posté le: 28 Sep 2006 15:49 Sujet du message: |
Ont dois bien le karting aux Américains  _________________
Nanard
Posté le: 30 Sep 2006 17:29 Sujet du message: |
ça doit etre sympa pour le drift  |
